Philco 650 MX
I just recently got a 650MX and the lid does not open properly. When closed the release button releases the lid but it only opens about an 1/8". I checked the mechanism and it is free and the spring is properly tensioned. Once the lid is opened about an inch then the spring will open it the rest of the way. Obviously there is something wrong with mechanism, but without seeing one that works properly it is hard to figure out what the problem is. Access to the mechanism is almost impossible without removing the speaker and chassis. So before I dive into it, I'm hoping for some advice.
Thanks in advance.
Greg
As I look at your photo I can see the right side of the door is slightly lower than the left. Maybe this is binding the hinge or the hinge is slightly bent. Take a closer look at that. Does the rest of the cabinet look that good? Nice one!
Good eye, unfortunately that is just the way the picture came out.  Here is a better picture of the whole radio.
Cheers
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2074 online users. [Complete List]
» 3 Member(s) | 2071 Guest(s)
