49-1450 Safety Glass
I have just acquired this Philco 49-1450. Does anyone know how to remove the front wood framed safety glass for cleaning. It looks very easy but I don't want to break anything. Thank You.
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
I have access to one I can look at. I think a couple of screws are removed and the frame tilts off.
Visit the world's worst TV restoration website.
http://evilfurnaceman.tripod.com
You're right! I found the two screws and the wood fame slid off nicely. Thank You so Much! C Felton
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3795 online users. [Complete List]
» 3 Member(s) | 3792 Guest(s)
