WHATZIT?
I have what appears to be a 3-way portable radio that looks and works like an old roll-top desk. It's a Philco, but I can't find the model number on it anywhere. Good-looking wooden cab portable. Has one loktal and 4 mini tubes. Any ideers?
I CANNOT get my 89 to oscillate!!! ARGHHHH!! When I get back to it, there are ways to combat this in Chuck's schematics on this model. I will try to bake the osc. coil with a heat gun and try different 36s. What a PITA!! Icon_cry I will actually have to READ what Chuck sent about oscillator problems.
Then I have a Philco Jr. model 80 to tend to. 4 tubes?? A CURTAIN BURNER? I hope it has a transformer power supply, but haven't checked it out yet. I may have to employ Chuck for the schematics. I always do. Man that cathedral is tiny!
Steve McDonald
Your portable could be a 46-350...
http://www.philcoradio.com/gallery/1946a.htm#h
a 48-360...
http://www.philcoradio.com/gallery/1948a.htm#l
(Incidentally, I now own a 48-300, and will be adding a photo of it in the Gallery soon.)
or a 49-607.
http://www.philcoradio.com/gallery/1949.htm#m
On the 89, also read these pages.
http://www.philcoradio.com/tech/89evol.htm
http://www.philcoradio.com/notebook/supercnv.htm
(Only use that last page if there is no way you can get that 36 tube to oscillate. This is a drastic modification.)
Finally, don't worry. The 80 has a power transformer; it is not a curtain burner.
Also:
I suggest you remove the oscillator coil and bake it in an oven for 30 minutes at 200 degrees. The heat from a heat gun could easily be too much for that coil. A controlled 200 degree heat will not harm the coil.
Set it on an old metal pan, covered in aluminum foil so the wax that will drip off goes onto the foil, not the pan.
Let it cool, make sure the windings are good, and reinstall.
OH MAN! Removing that osc coil? YUCK! I'll do it if I have to though. What the heck, my 19LZ has the same chassis as 89, but WITH a shadowmeter. It's RF coil opened on me! Back out it has to come. I'll end up being a real champ at doing these darned things. BAH!
The portable turns out to be a 48-360. Faux alligator skin! Real clean, but there is a big X on the top of the filter can. I hope that doesn't mean.....there must be NINE sections on that sucker! I get all the luck, lol . I wonder what a faux alligator looks like...??
Steve McDonald
The portable turns out to be a 48-360, faux alligator skin and all. I wonder what a faux alligator looks like....?? It's in great shape. Too bad it didn't have a battery in it to have Bill the battery-maker make a replica battery for it.
Gee, I can't WAIT to remove that oscillator coil on the 89! 19 wires and all! But I may have to do just that. I'm not afraid to do it, but I AM lazy! Icon_problem Hmmmm, maybe I can do it up like one of those Thomas repro things, with an MP-3 player and CD player. Ron, you can smack me at any time! Icon_thumbdown
Then I have two 38-10s with the same problem.. the rubber separating the tuner frame and the chassis is gone. If you've never seen the tuning cap on one of these, you really should! I don't quite know how to address that, so the 2 clone radios languish. I have a whole lineup of Philco radios waiting for a turn on my bench.
Thankfully, that Philco 80 has a power transformer. And it has 2 36s in it!! I hope it will oscillate! HEE HEE HEE!
Then, I've never finished that %&@(^*^(&%^& 16B that only has audio. I will have to learn to use a signal tracer to figure out where my boo-boo is.... I will eventually finish all these before I croak....I HOPE!
Steve McDonald
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
There are currently 2482 online users. [Complete List]
» 3 Member(s) | 2479 Guest(s)
