Local Find
Found a Philco TV, AM/FM radio and phonograph at my local Flea Market. Price listed is $50. Model # is 53-XXX. Should of wrote it down! Is is worth it? Looks to be complete with knobs and tubes. Nice piece of furniture! I don't want to get in over my head but the price seems right.
thanks
Chris
Go for it. The only concern I would have is the CRT. This should be before those wonderful couplated found in the Predicta and later sets. It should be an easy restoration.
Visit the world's worst TV restoration website.
http://evilfurnaceman.tripod.com
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4541 online users. [Complete List]
» 1 Member(s) | 4540 Guest(s)
