Philco 48-382
My friend emailed me about my fixing his radio. I can't find it in the gallery.
Bet it's a 48-482 it's an AM/FM job.
Terry is right, as there is no such thing as a 48-382.
Hmmm.....he even checked the # twice.....also mentioned SW.....I'll see
He just sent me the pic......it's a 48-482
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 2948 online users. [Complete List]
» 2 Member(s) | 2946 Guest(s)
