Philco Stereo - need needle
I am looking for the model # of a needle that is needed for a Philco Stereophonic Console stereo with AM/FM. On the back there is a paper with Model 1884 written on it. The record player is capable of playing speeds 16, 33, 45, 78. If anyone can help, it would be appreciated.
Thanks
Picture of pickup head might help, could be a really easy to get part.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
