mica caps 38-116 Philco
Have a question for the philco experts.
Working on a 116 coded 121 and have a questionable mica cap.
If you look at Riders 8-85 there is a view looking underneath on the far left of the page.
If you look at items 31 or 32 on the parts list, they are specified as mica caps 250 mmf.
Is there a voltage rating on these if I  were to replace them?
One in question goes from the 5th trimmer shown in that view to ground.
Schematics are vague in this area.
I could send a pic if your not clear on what I am looking at.
Would like to replace it as someone in the past has done a crappy job of tying one in there.
murf
 Hi murf, I'm no expert by far, but if you have any 250mmfs I would remove one leg of the one you plan to replace and just jumper a new one in to see if it makes a difference. The voltages that would be minimum for that part of circuit I can't tell you for sure.
Heres a place that offer high voltage rated micas.
http://www.justradios.com/mica.html
Good luck.
They are probably 500wv. There is hv on them from the 6A8. Would check them for leakage the value before bothering to replacing. It's part of the tuning magnet circuit.
Philco 39-116 radio and remote
Hi Brad, Thanks so much for the info!  Do you happen to have the specs for the PT-86 transformer?  I did not find a lis...RichG — 04:32 PM
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran; If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM
Sorry, Chas. Re the burns, I broke my first TV at the age of 3.  Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM
Mr fixr, That is great news I would love to see repo grille !! I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM
Hi Rod, I always tell people that my scars give me character.  :wink:   Great job on the radio.  Is the grille origi...MrFixr55 — 08:00 AM
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM
Hello Chas. Radiomuseum has information on both sets.  Thanks Gary, lots of good info there. Perhaps we'll ha...ChasL0001 — 02:23 AM
