Philco Bathtub Block 3903AH ?
Can't find a listing on this one.
Assume it is a .01 Block
It was changed at some point according to Philco to 3903 SG . Nothing on it either.
Bob T
Yes is a 0.01 uF cap as seen below:
[Image: https://dl.dropboxusercontent.com/u/5462...903-AH.jpg]
3903-SG would be a lower melting point wax than the 3903-0SG  (the O was for higher temp wax) but should have the same configuration.  See Ron's post of Bakelite Condenser Data or Chuck's Bakelite Block Values page.
(05-29-2016, 05:25 PM)klondike98 Wrote:  Yes is a 0.01 uF cap as seen below:
Thank you Sir. Only 6 more to go on the 16
Bob T
If you have not seen it, here is a nice thread on restuffing these caps.
http://philcoradio.com/phorum/showthread.php?tid=9107
(05-30-2016, 07:04 AM)klondike98 Wrote:  If you have not seen it, here is a nice thread on restuffing these caps.
I use to use my Commercial Heat Gun to remove the Blocks. No More
Before Doing this Procedure check and know what your Block Contains. Blocks containing Resistors DO NOT DRILL
Now I have used the method by cutting the wires on top of Block where the inside parts are soldered. Then drilling a small size drill dead center of Tar , yes drill right on through the Caps inside.
Once you have drilled to the Bakelite, stop.  Then I use a fine thread sheet rock screw 1 1/2" long
Thread it in slowly into your drilled hole with a Phillips screwdriver. You will be amazed as you seen the entire Tar block Caps and all slowly come out.
Has not failed me yet.
Been using it on the 14 Block 16B I am working on.
Just remember to FIRST cut the wires on top where the internal parts are soldered to.
This is not my idea, I believe I saw this method over on Chuck's Site.
Bob T
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 3924 online users. [Complete List]
» 2 Member(s) | 3922 Guest(s)
