680 decals
Just got the decals for my 680.  There are 2 types,  one with the high fidelity in a script,  the other in plain type i looked at the photos on this site as well as the radiomuseum site and the decal cant be made out. Does anybody know which one is correct for the 680X late production? Thanks in advance  Norman
Plain type, not script. The script version ("High Fidelity" in script) was used on models 38-116XX and 38-690XX only.
Thank you, Mr Ramirez
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5137 online users. [Complete List]
» 1 Member(s) | 5136 Guest(s)
