Another Model ID Request
What model is this?
I believe that's a 42-327T:
http://www.philcoradio.com/gallery/1942a.htm#l
Wow, 2 minutes,  that has got to be a record time for a reply. Thanks.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
