philco 47-1230 another strange cap
Found two of these in the FM section of my chassis, don't know what they are. Anyone recognize this.
[Image: http://i1281.photobucket.com/albums/a508...kzjfyy.jpg]
That is a 10,000pf/.01uf polystyrene capacitor.
Gregb
The J usually also means 5%.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4367 online users. [Complete List]
» 1 Member(s) | 4366 Guest(s)
