Threads: 24
City: Edmonton AB CA
Has anyone bought chassis labels from this fellow, see link below. His ad says he will make what ever label set you want so I asked him for a set for my model 17B and he emailed back and said he's to busy and can't do it. Seems to be a little false advertising to me.
http://www.ebay.com/itm/Philco-Tube-Radi...xycmBS3icT
Gregb
Threads: 310
City: Kings Park NY
Avoid him..
Stuff is crap and he is not a nice person or a good salesman...
Me
AC: 4 DC: 1
Threads: 24
Your are absolutely correct in that statement!
Gregb
Threads: 212
City: Seattle
State, Province, Country: WA
Chuck Paci (cpaci1 at Verizon dot net) sells photo reproductions of original labels.
I'd also be happy to help make some (for the fun of it) - but these would be reproductions rather than scans.
Just to confirm, this is the radio you have:
Gallery link:
http://www.philcoradio.com/gallery/1933b.htm#f
Assuming that's right, here are examples of labels from the 17B:
Chassis label
The chassis label looks pretty much like this 16B label:
http://philcoradio.com/phorum/showthread.php?tid=13832
Patent label
The patent label is essentially the same as this one, just printed larger:
http://philcoradio.com/phorum/showthread...#pid118218
Tube layout label
Threads: 24
Thanks Nathan, that is the radio! If you would make me a set that would be greatly appreciated. PM me the details.
Gregb
Threads: 22
City: Waxahachie, TX
(12-23-2016, 06:52 PM)OldRestorer Wrote: Avoid him..
Me
Ditto!
Crist
Threads: 212
City: Seattle
Repro labels for the 17B added to the Downloads section:
http://philcoradio.com/phorum/showthread.php?tid=16003
Threads: 26
City: Wilmington
State, Province, Country: NC
(12-25-2016, 07:25 AM)Crist Rigotti Wrote: (12-23-2016, 06:52 PM)OldRestorer Wrote: Avoid him..
Me
Ditto!
DITTO AGAIN
Bob T
Got stung with Crap. He just does not care
Threads: 551
City: Jackson, NJ
Chuck seems to make good labels, plus some other things like tube shields. Can't say anything on the seller in question, but I usually go to the people I know and trust first.
Threads: 337
City: lawrenceville nj
So why not try ones Nathan uploaded
Sam
Threads: 22
Well, I got stung by this guy again. Avoid Vintage Radio Labels.
I need a foil RCA "Golden Throat" Label for my 1946 RCA 621TS TV that I'm restoring. He had one and I bit. Here is what he advertised and what I received. A paper one and notice the ladies face color!
[Image: http://i1060.photobucket.com/albums/t458...ndwnzz.jpg]
I may contact Nathan. He is skilled and does a great job on these things.
Crist
(This post was last modified: 04-01-2017, 03:39 PM by Crist Rigotti.)
Threads: 212
City: Seattle
Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality.
Let me know if I can help. From the examples of that label I've seen online it's a bit of a tricky one to reproduce because it requires a gold background (which is normally OK - that just means printing on gold paper with a color laser printer) but also white lettering. Obviously most printers don't print white (or gold), which makes having both in the same label a bit of a problem. Probably the best you could do with a regular printer would be to print the golden-yellow rather than have it be metallic.
Threads: 551
City: Jackson, NJ
Crist
Do you know the joke about stepping twice on the same rake?
Threads: 22
(04-01-2017, 06:32 PM)morzh Wrote: Crist
Apparently not!
Crist
Threads: 22
(04-01-2017, 06:15 PM)Nathan Slingerland Wrote: Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality.
Nathan,
Got your email. Looking into this label a little deeper. I need a good size dimension to begin with. We'll keep in touch over the next few days.
Crist
Delco car radio Peko vibrator converstion issues
Rich,
There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM |
Jackson 715 not working
Mrfixr55, its working now. I cleaned the switches and sockets with spray cleaner. Thanks for helping on this one.daveone23 — 06:26 PM |
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
There are currently 3414 online users. [Complete List] » 2 Member(s) | 3412 Guest(s)
