model 17 L 1933
Hi I am new here...I have had this radio in my famly for many years,everything seems to work fine...wood cabinet could use some work...someone has put urathane on it and didn`t do a very good job...I am a cabinet maker buy trade,and I an thinking about refinishing it...Does any one have ideas what I should use to strip this or should I sand this...I am planing to use this for a tv show and could use some ideas...thay say there were only 2,200 made and the price back then 1933 sold for around 100 dolars... is this correct...any information would be helpfull......Thanks[attachment=3][attachment=3][attachment=3]
Hi and welcome. Your posting will be
better served in the correct Phorum Section.
Chuck
Welcome, grantman007.
Your 17L will be really nice once you restore it.
A lot of people use Citri-Strip to remove the old finish. Others use a cabinet scraper to scrape the old finish. Whatever you do, I strongly caution you against sanding the cabinet any more than is absolutely necessary! The veneers are very thin and if you go overboard with sanding, you can easily sand through the veneer. So, try to avoid sanding when stripping the cabinet. 4/0 (extra fine) steel wool will be better.
The original finish was tinted lacquer. Mohawk's Medium Walnut would be an excellent toning lacquer for this cabinet, followed by coats of clear gloss lacquer, carefully wet sanded with very, very fine sandpaper (800 grit or better).
grantman007 Wrote:thay say there were only 2,200 made and the price back then 1933 sold for around 100 dolars... is this correct...
Ummm...yes...
http://www.philcoradio.com/gallery/1933b.htm#g
This info was taken from Philco Furniture History, an in-house Philco document which gives data on nearly all Philco cabinets.
RCA WV-98c
If this is R22, check the voltage on the wiper (86V). If this is R33, see if the lower pin indeed connected to GND, the ...morzh — 02:29 PM
Philco 38-2 Low Volume
Both sch, the one you showed in the beginning and the one I see on Nostalgia, show 40K for the 2nd audio plate.morzh — 02:25 PM
Model 96 cabinet veneer
I can't figure out what the first step is, let alone the final step. I have tried copying pictures from my hard drive a...TGLager — 01:40 PM
I managed to get some more time on this. Hi Mr. FixIT, The radio has been recapped. Many of the resistors were rep...dconant — 01:39 PM
Thanks guys for the help. I started looking at these points but I have to quit for the day. I will be looking into this ...dconant — 12:23 PM
RCA WV-98c
Check out this crazy zero pot operation. Touching it drives it crazy. Its rubber tipped. Also the 6al5 has no negative v...daveone23 — 12:08 PM
If you check all of that and still have a problem (my first inkling would be one of the 6F6s) then look at the 6J5 phase...RodB — 10:44 AM
RCA WV-98c
Those will probably depend on teh switch combination. Could you list some that you see, their values and what they sh...morzh — 10:26 AM
You are probably skipping the final step. Once you select the photos you want and they get downloaded, the system assign...RodB — 09:36 AM
RCA WV-98c
At this point, there is no input, just internal voltages Which are incorrect and not sure what they should be.daveone23 — 09:15 AM
There are currently 1235 online users. [Complete List]
» 3 Member(s) | 1232 Guest(s)
