Thinning Mohawk M608-4226 Grain filler
Threads: 22
City: Kewanee
State, Province, Country: Illinois
Guys I got my supplies from Mohawk and have begun the process on my 40-158 cabinet. I have it sanded and sealed and tomorrow I plan to do the grain filler. I have not opened the can yet, so I'm not sure of the consistency, however I did not know it required a specific thinner from Mohawk if required. They call it Grain Filler Solvent M608-106 and I don't have any. Is there something I can purchase locally to mix with it to thin it if required? Paint thinner, lacquer thinner, etc.? I don't know what the base is. Is anyone using this filler using anything other than the Mohawk Grain Filler Solvent? Thanks!
Gregg
Threads: 269
City: Bandon
State, Province, Country: OR
I have not used that grain filler so hopefully someone with direct experience will offer some advice. In the absence of anyone else responding.... The MSDS for the Mohawk solvent lists petroleum distillates and aliphatic petroleum distillates as the ingredients. Mineral spirits is also a petroleum distillate although perhaps a different fraction or mixture than the Mohawk solvent but would probably work for you.
Threads: 22
City: Kewanee
Thank you Bob! I will give that a shot.
Gregg
Threads: 76
City: Winter Haven, FL
I use Timbermate. http://www.timbermate.com.au/. It's water-based. You can use it thick, right out of the container, as wood dough, or thin it to the consistancy of a milk shake for a grain filler. It drys fast, sands easy, and accepts any kind of stain. And there is no waste, because what ever is left over in your mixing tub can be re-constituted with a little water. It's great stuff!
Pat
Threads: 269
City: Bandon
yep...I've used Timbermate as well!
Threads: 268
If you haven't opened the can, inside the filler is very thick and the solvent has migrated to the top. I use a small container, scoop out some of the filler and add some of the solvent from the top to mix and thin. Don't think thinning will be an issue till you get near the bottom of the can if then. As Bob mentioned oms is a good choice if you do need some extra solvent.
(This post was last modified: 10-08-2018, 11:37 AM by Radioroslyn.)
Threads: 22
City: Kewanee
Awesome, thank you.
Gregg
Philco 39-116 radio and remote
Hi Brad,
Thanks so much for the info! Do you happen to have the specs for the PT-86 transformer? I did not find a lis...RichG — 04:32 PM |
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran;
If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM |
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM |
Sorry, Chas.
Re the burns, I broke my first TV at the age of 3. Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM |
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM |
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM |
Mr fixr,
That is great news I would love to see repo grille !!
I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM |
Hi Rod,
I always tell people that my scars give me character. :wink: Great job on the radio. Is the grille origi...MrFixr55 — 08:00 AM |
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM |
Hello Chas. Radiomuseum has information on both sets.
Thanks Gary, lots of good info there.
Perhaps we'll ha...ChasL0001 — 02:23 AM |
There are currently 2819 online users. [Complete List] » 1 Member(s) | 2818 Guest(s)
