Philco Model 52GC
OK Fellow Philco collectors.   I believe I have the actual model 52 GC that is pictured in the Philco Library Gallery.  The one pictured in the gallery has the same hunk of wood missing from the trim at the top just to the right of the final and the same faded cloth.  I bought it from a collector in southern IL just east of St. Louis over a year ago.  The guy told me that Ron had stopped there to see it years ago due to its rarity.  I just finished the restoration of the chassis and tonight I was able to repair clean and get the original clock running.  Pretty excited about it to tell the truth.  Not sure If I want to refinish it but I am looking for Insite on the correct speaker cloth and a source for it.  I have a couple of shots attached.  One shows the faded front view and another a shot from behind that shows what the pattern looked like.  Anyone know where I can get this pattern of cloth or if it's even correct?
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
