My Hershey car show prize!
I like these style stands for radios. Sort of like creating a skeletal console when you use these stands with the radios and speakers. I have seen similar stands for Atwater-Kent radios, but this is the first with a Philco on it that I have seen.
glennpr Wrote:What a great find!! I google searched the table manufacturer. I found something I thought was interesting:
http://www.crosleyradios.com/pdf/Broadcaster_020129.pdf
look at page 13 it shows a table from the same manufacturer, looks similar. The whole "magazine" is pretty interesting, of course it's slanted toward a particular manufacturer, which I won't name.. Icon_smile
Glenn
Hey Glenn, thanks for the link! The design is very similiar. very cool!
The entertainment center furniture of the 1920's.....
Great find. Reminds me a bit of the A-K radio of the same era.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4669 online users. [Complete List]
» 1 Member(s) | 4668 Guest(s)
