Philco 46-200 122 SW Band?
Hi everybody,
Finally got my little Philco 46-200 122 working, but for the life of me, I can't figure out how the SW band works. The dial is marked Broadcast and 200 to 500 meters, but no band-switch.
Using the Breitman Schematic.
I hesitated to ask because it's probably obvious. Just not to me.
lyle
I may not be very good, but I'm slow.
Huh the 200-500 meters is the AM band measured in wavelength rather than frequency. This set has no SW band.
No wonder I couldn't find it. See, it was obvious.
Thanks once again, Terry.
lyle
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5154 online users. [Complete List]
» 1 Member(s) | 5153 Guest(s)
