Threads: 531
City: Jackson, NJ
Wanted to pick your brains, guys.
The radio came.
Yes cosmetically it is very good and the chassis seems to be OK.
When taking the radio out of the box (packed real well) I heard some banging....I looked inside when I unpacked it; the speaker was loose.
But that'd be OK as long as it did not destroy anything (which it seemingly did not, or at least I do not see any damage); the problem is, the radio was obviously a subject to someone attempt to restore it (which we knew from Ron's comments) and the grillcloth was stretched over a solid piece of something, with no slits or a hole for the speaker, and the speaker is not bolted to anything at all.
My guess is, the restorer relied on the speaker to remain in a tilted position (it is propped up by the power tranny) for the sound to move in front of the cone; otherwise it would be a problem.
So, should I let it go or do you think that will be too much work to do? The cloth is stretched over some bending radius, so it is not as simple as simply stretching it over a rectangular board.
What do you guys think?
Again, it looks beautiful otherwise; the question is how much trouble it is to re-mount the speaker (if it survived the shipping of course - to test it now is not that easy).
(This post was last modified: 04-09-2013, 02:12 PM by morzh.)
Threads: 409
City: Boston
Any pic's?
Threads: 531
City: Jackson, NJ
Here are the pics.
Obviously the opening is there, but the speaker is secured to the chassis (sort of like in portable radios) and not to the cabinet.
But it is possible the speaker is no original, so the make-shift bracket was concocted from a piece of aluminum, and the screws are short and during the transportation they just let go.
(This post was last modified: 02-02-2013, 08:37 PM by morzh.)
Threads: 531
City: Jackson, NJ
More pics:
The speaker of course was repaired for multiple tears.
Your speaker is definitely not original.
[Image: http://i326.photobucket.com/albums/k420/...27760f.jpg]
See where a bracket was once fastened on the chassis behind the speaker? This bracket was fastened to the original speaker.
[Image: http://i326.photobucket.com/albums/k420/...f5a6f4.jpg]
Yup, that's a homemade bracket on the front of that speaker. The original had a bracket here, also.
Looks like you need a speaker. You can use one from either a 38-15 or a 38-12, as the field coils have the same resistance.
Threads: 531
City: Jackson, NJ
thanks Ron.
yes I realized it is not original, otherwise there'd be no makeshift brackets.
I could probably fix the radio using this one, and then try to buy a genuine one.
What I want to hear is, in your opinion, do you think it's worth it?
Threads: 531
City: Jackson, NJ
Just went to look for Philco speakers: Ebay has some, but of course not mine.
If anyone knows of any that Ron pointed, please keep me in mind.
Threads: 409
City: Boston
Morzh-
Maybe Jeffrey G has one, if not posted for sale you can ask, he has parts, a lot of parts.
http://radiotiques.com/forsale.asp?Tab=Tube
Good luck....
Pablo
Threads: 531
City: Jackson, NJ
Thanks, Paul
I did not even know this place.
I will sure ask.
Mike.
morzh Wrote:What I want to hear is, in your opinion, do you think it's worth it?
Yes, I think so. The cabinet looks much better than most, and the dial scale (which is quite fragile because of the foil) looks very nice.
Here are a couple more Philco models that have speakers which will work: 39-6, 39-7. The field coils in these are 1700 ohms instead of the 1500 ohm field used in the 38-12 and 38-15 speakers - close enough. The higher field will just drop your B+ a little bit, not necessarily a bad thing.
Threads: 531
City: Jackson, NJ
Thanks Ron, I was also leaning towards keeping it.
Worst case I will make it work with the existing speaker and then will be looking for the original one in the background.
Threads: 51
I would make do with the speaker that's in there, but perhaps come up with a more secure way of mounting it. It looks a bit like a Utah made speaker from the 1950s or so, a lot of parts catalogs from the 1940s through the 60s used to carry Utah replacement speakers.
Threads: 531
City: Jackson, NJ
Thanks Arran,
I could try that too.
As I stated many times, I am not too good with anything that involves drilling, hammering, winding or such. The soldering is the exception - I am very good with it, despite my shaky hands.
So I need to see if making a better mount is something that an inept mechanical ignoramus like myself can take care of or if it is something that is beyond my wildest imagination and is akin to making a rocket engine for a real spacecraft.
In which case it is easier for me to shell some dough provided the merchandize does exist anywhere at all and within my disposable income and can be safely concealed from my ol'lady
Threads: 531
City: Jackson, NJ
Sorry.
I posted here something that belongs to another thread, the WR-212.
(This post was last modified: 02-09-2013, 04:04 PM by morzh.)
Threads: 531
City: Jackson, NJ
OK, so now that I am more or less done with the 18, I eventually got back to this one.
This is the sch.
http://www.nostalgiaair.org/PagesByModel...013239.pdf
Took some pics of the underbelly.
The set was repaired at some point and that point was probably when I was..well, not in diapers - we did not have diapers, but as we say when I was able to walk under the dinner table without stooping, which I think translates as knee-high to a grasshopper.
It was done fairly neatly - the "new" cap is secured with a tin band soldered to the chassis (I thought the chassis was aluminum but soldering indicates otherwise, probably steel).
You can see a cut wire from the original cap, which was not removed.
It's the grey cap at the top-center of the chassis.
It is 16uF and not 12uF like it should be, but I guess that much deviation is OK.
Oh! Is it me, or did Philco connect the capacitors across the power cord without discharge path? Granted, it is 5nF equivalent but it will give you a painful pinch if touched after it was extracted from the outlet during the peak voltage.
Since it is a RPITB to re-rout it I intend to introduce a 1M resistor just across. The caps need changing anyway, the only backelite block in the whole set. The rest seem to be the tubulars. They all marked as PHILCO so I intend to keep the shells to hide the yellow.
OK! Good luck to me!
(This post was last modified: 04-06-2013, 04:01 PM by morzh.)
