Philco Model 131?
Is this model Canadian? Here is the info I have.
PHILCO MODEL 131, 4 TUBES, AM BAND, BATTERY OPERATED. I can not find any info on it.
thanks
Chris
No Canadian model by that number that I'm aware of.
That's a Model 46-131, I believe you're looking for?
4 tubes: 1LA6, 1LN5, 1LH4, 1A5.
Or is could be a 42-131, also four tubes: 1LA6, 1LN5, 1LH4, 1LA4.
Chuck here is a picture of it. I could not find pictures of it in Ron's book.
http://cgi.ebay.com/270184185168
Any help would be appreciated.
Chris
Yep, that's the Model 42-131.
A picture is not in Ron's original book.
Chuck,
Thanks for the info. Was this model rare?
Chris
Only 10,550 were made, so it's not a commonly found model and fairly rare. Originally introduced in the Jan-Mar 1942 season.
Thanks Chuck for the info. How hard would it be to recone the speaker or find a replacement?
Chris
Hi Chris
Did you buy it? Someone did...quite a bargain.
Being a battery set, the speaker is likely PM so replacement would be easy. Only problems would be matching the voice coil and mounting holes.
Ron,
No I missed out on it. I went to check on it again and someone bought it Icon_sad
Chris
Well, at that price, I thought about picking it up...but I do not need it. Too bad you missed out. Honestly, though, I am surprised it lasted as long as it did before being snapped up.
Same here I do not need it either. Picked up a Philco AM/FM for $20 total. That will be it for awhile. I have enough projects for the winter now unless something special comes along Icon_wink
Chris
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 2524 online users. [Complete List]
» 2 Member(s) | 2522 Guest(s)
