Predicta inspired PC
This is kind of cool.  A PC design that was inspired by the Predicta.  http://www.schultzeworks.com/philcopc/
[Image: https://www.dropbox.com/s/7q7hcv52rak7gx....png?raw=1]
That is pretty neat!
That is way cool.. and I absolutely love that keyboard!
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4321 online users. [Complete List]
» 1 Member(s) | 4320 Guest(s)
