1934 Ford Ashtray control head
I'm familiar with the glove box sets for the '34 Ford. I've owned a few  The Zenith sets were very good ones, and possibly, the Majestics were right with them, except for Majestic's daffy power supply. .
But I'd like to see what the radio case looks like that is used with the control head for the '34 Ford. Is it the same as on the 35-36 Ford sets?, It's a conventional cable control head, like later models.
Anybody know?
I'm afraid I don't, sorry. I've never seen one.
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5264 online users. [Complete List]
» 1 Member(s) | 5263 Guest(s)
