sounds like there playing under water
Many times the loop antenna is the D.C. path to the first grid of the converter/mixer tube for the AVC voltage.
With no gain "throttle" on the front end of the set, it's running "wide open" and stations will be overloading the front-end, and then the IF stage
and the detector causing the audio distortion you hear.
sounds like there playing under water - by Guest - 08-26-2009, 09:42 PM
Re: sounds like there playing under water - by Guest - 08-28-2009, 03:41 PM
Re: sounds like there playing under water - by Chuck Schwark - 08-29-2009, 03:51 PM
Re: sounds like there playing under water - by Guest - 09-02-2009, 09:16 PM
