Hickok 600A Calibration
So late to this but - -
The value of testing any power tube in a tube tester is limited to the shorts test and maybe the noise test - grid emissions.
I have restored a lot of tube type hi-fi gear, kept most of it, and I can tell you that a tube that tests good on the 600A or a TV-7 or most tube testers can run poorly in a amplifier or even red-plate. They just do not come close enough to the real operating environment to give an accurate test.
Most of the amps I have use 7868 tubes , a 6L6© variant. So I wanted to test them accurately. I had a good quality mono amp that was set up to run them near their max spec. It was converted into a test rig that can be used to measure the plate current, bias and the interaction between a push pull pair (comparison of plate currents/on known bias).
I also built one of these for 6BQ5s.
You can, and should do this test in the device that the tubes are to be used in - lacking a test fixture such as this. Some modifications may be required.
Hickok 600A Calibration - by etech - 01-12-2016, 05:13 PM
RE: Hickok 600A Calibration - by etech - 01-18-2016, 12:21 PM
RE: Hickok 600A Calibration - by Eliot Ness - 01-18-2016, 01:48 PM
RE: Hickok 600A Calibration - by etech - 01-18-2016, 05:46 PM
RE: Hickok 600A Calibration - by Eliot Ness - 01-18-2016, 07:20 PM
RE: Hickok 600A Calibration - by morzh - 01-18-2016, 08:02 PM
RE: Hickok 600A Calibration - by codefox1 - 01-19-2016, 12:36 PM
RE: Hickok 600A Calibration - by etech - 01-19-2016, 05:48 PM
RE: Hickok 600A Calibration - by TA Forbes - 02-15-2016, 03:35 PM
RE: Hickok 600A Calibration - by keith49vj3 - 03-26-2016, 08:50 AM
RE: Hickok 600A Calibration - by morzh - 03-26-2016, 11:45 AM
RE: Hickok 600A Calibration - by TV MAN - 03-29-2016, 08:51 AM
RE: Hickok 600A Calibration - by Steve McDonald - 04-13-2016, 01:38 PM
RE: Hickok 600A Calibration - by Phlogiston - 10-25-2016, 11:55 AM
RE: Hickok 600A Calibration - by Phlogiston - 10-25-2016, 11:51 AM
