42-321 Questions
http://www.nostalgiaair.org/pagesbymodel...013512.pdf
Value of the resistor isn't particularly critical as it's in the positive side of the hv. If it was in the negative side then it would change the amount of negative bias voltage available. So looks like the original is about 500ohms, I would go a bit higher around 1000-1500ohm @ 2-5W. You'll need to boost the value of the filter caps too as the resistor isn't very efficient at eliminating hum like a choke is. Would use 2-47mf @160v.
RE: 42-321 Questions - by klondike98 - 10-27-2016, 07:55 AM
RE: 42-321 Questions - by Paperboy - 10-27-2016, 02:31 PM
RE: 42-321 Questions - by morzh - 10-27-2016, 03:33 PM
RE: 42-321 Questions - by Radioroslyn - 10-27-2016, 03:35 PM
RE: 42-321 Questions - by morzh - 10-27-2016, 05:14 PM
RE: 42-321 Questions - by Paperboy - 10-28-2016, 09:19 AM
RE: 42-321 Questions - by Radioroslyn - 10-28-2016, 03:29 PM
RE: 42-321 Questions - by Paperboy - 10-28-2016, 10:02 PM
RE: 42-321 Questions - by Radioroslyn - 10-28-2016, 10:38 PM
RE: 42-321 Questions - by Paperboy - 10-29-2016, 08:28 AM
RE: 42-321 Questions - by Radioroslyn - 10-29-2016, 09:16 AM
RE: 42-321 Questions - by Paperboy - 11-04-2016, 10:39 AM
42-321 philco paper behind dial - by Paperboy - 10-27-2016, 07:38 AM
