Update on 38-5 restoration, Almost ready for cabinet!
(10-29-2016, 07:35 PM)TerryMSU Wrote:  Ron, my personal inclination would have been to stick with a field coil design as you suggested for the exact reasons you suggest.  Terry, the magnetic field is proportional to the product of turn count and .  Double the turn count and you can use half the current.  In any case, I am very appreciative of the input all three of you folks have provided.  While I have the engineering knowledge and experience to know what might be possible, I am lacking in the practical wisdom that you all have provided.  If the cabinet I am considering pans out and my current chassis is functional, I will definitely be looking for more advice.  The idea of other Philco speakers in a similar size had not crossed my mind.
The cabinet (if I take it) will be coming from Alabama to Michigan.  Any recommendations on how to ship it safely and cheaply?
Thanks so much,
TerryMSU
This is true but you end up with a coil that is physically larger in less you shrink the size of the wire.
In terms of using and resistor I was thinking of cost also  (it's cheap like me). A choke (or field coil) is much more efficient in reducing ac hum in comparison to a resistor. If the resistor was the same size FC I would think that the heat generated would be about to same as weather you are use either, both are dissipating the same amount of energy.
You can use a separate choke mounted on the basket of a pm spkr, mounted like the opt. Something like 5H @ 70ma should do the trick. You could go higher in inductance but size maybe an issue.
If you want to have a set that looks original by all means go with a Philco spkr but I'm thinking it may be a bit harder to find and may need reconing.
Just wanted to throw out the most options.
RE: Question on philco 38-5 restoration - by Radioroslyn - 10-29-2016, 09:43 PM
