10-29-2016, 10:50 PM
Terry,
I found one of your posts from 2011 about the same issue. I just checked the antenna coil. From the antenna terminal to the ground terminal the coil is showing open. Radio un-plugged and volume control all the way up.
The oscillator coil, from pin 1 to ground, 3 ohms. From 2 to ground open. from 3 to ground 2.5 ohms. (Viewed from bottom clockwise direction).
All resistors were replaced except the 1 meg. It was the only one good and was actually within 5%.
I will try the transistor radio test in the morning. getting too late tonight.
