Philco 84 code 121 no sound
Also check the two ground connection, one at the cathode of the 2nd 77 tube it's done though a rivet which maybe a problem and the tap on the 2ndary or the IF coil.
Philco 84 code 121 no sound - by Mike L - 10-24-2016, 05:55 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-24-2016, 07:14 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-25-2016, 06:34 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-25-2016, 07:07 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-29-2016, 09:42 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-29-2016, 10:19 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-29-2016, 10:50 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-29-2016, 11:27 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 08:46 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 10:07 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 01:15 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 03:11 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 03:55 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-30-2016, 05:32 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-30-2016, 06:51 PM
RE: Philco 84 code 121 no sound - by Mike L - 10-31-2016, 06:31 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 10-31-2016, 07:23 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-01-2016, 06:46 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-01-2016, 09:15 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-02-2016, 06:25 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-02-2016, 07:34 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-02-2016, 08:07 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-02-2016, 08:17 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-03-2016, 07:08 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-03-2016, 07:34 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-09-2016, 01:22 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-09-2016, 10:44 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-09-2016, 11:05 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 02:52 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-11-2016, 02:59 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 06:13 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-11-2016, 06:21 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-11-2016, 06:29 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-12-2016, 11:04 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-12-2016, 11:34 PM
RE: Philco 84 code 121 no sound - by klondike98 - 11-13-2016, 07:56 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 08:45 AM
RE: Philco 84 code 121 no sound - by klondike98 - 11-13-2016, 08:48 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 11:01 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-13-2016, 02:53 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-13-2016, 07:20 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-13-2016, 11:35 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-14-2016, 07:40 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-14-2016, 08:47 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-14-2016, 09:25 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-15-2016, 12:04 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-19-2016, 03:27 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-19-2016, 10:28 PM
RE: Philco 84 code 121 no sound - by Mike L - 11-20-2016, 10:16 AM
RE: Philco 84 code 121 no sound - by KCMike - 11-20-2016, 10:36 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 10:44 AM
RE: Philco 84 code 121 no sound - by morzh - 11-20-2016, 10:49 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 10:57 AM
RE: Philco 84 code 121 no sound - by morzh - 11-20-2016, 11:01 AM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 11:12 AM
RE: Philco 84 code 121 no sound - by Mike L - 11-20-2016, 12:54 PM
RE: Philco 84 code 121 no sound - by Radioroslyn - 11-20-2016, 06:33 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3996 online users. [Complete List]
» 1 Member(s) | 3995 Guest(s)
