Zenith TO Knob Bright Removal
Now that the chassis' done I've gotten around to the cabinet.
I haven't decided how to remove the brights yet, but I did try buffing one on the knob. Do you know that if you buff it enough brass turns to silver  Icon_eek -- oops! They're so small, I figured they'd be solid brass.
I'll either get some plating compound and fix the originals or take the coward's way out and use the spare, bright-less knobs I have with the repro brights I got from Antique Electronic Supply a while back. They don't seem to carry them any more.
Greg O.
Whitehall, PA
Zenith TO Knob Bright Removal - by Greg - 11-10-2016, 11:13 PM
RE: Zenith TO Knob Bright Removal - by klondike98 - 11-11-2016, 07:32 AM
RE: Zenith TO Knob Bright Removal - by morzh - 11-11-2016, 08:27 AM
RE: Zenith TO Knob Bright Removal - by Phlogiston - 11-11-2016, 02:37 PM
RE: Zenith TO Knob Bright Removal - by klondike98 - 11-11-2016, 06:55 PM
RE: Zenith TO Knob Bright Removal - by Greg - 12-05-2016, 11:20 PM
RE: Zenith TO Knob Bright Removal - by Arran - 12-12-2016, 03:18 AM
RE: Zenith TO Knob Bright Removal - by Greg - 12-13-2016, 08:19 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
I was wondering if I could use a more common Philco speaker and just add the resistance I need for the coil and get a ne...dconant — 07:45 AM
There are currently 1881 online users. [Complete List]
» 3 Member(s) | 1878 Guest(s)
