Sherwood S-7900A
You call THAT high voltage? Ron, solid state is getting to you.
1. Those are not the death caps.
2. They do not need to be Y-caps.
3. Leave them be.
Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 07:17 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 07:21 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 07:23 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 07:26 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 07:29 PM
RE: Sherwood S-7900A - by Arran - 06-26-2016, 03:00 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-25-2016, 07:35 PM
RE: Sherwood S-7900A - by morzh - 06-26-2016, 10:46 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-26-2016, 04:29 PM
RE: Sherwood S-7900A - by KCMike - 06-26-2016, 05:20 PM
RE: Sherwood S-7900A - by Eliot Ness - 06-26-2016, 05:52 PM
RE: Sherwood S-7900A - by Ron Ramirez - 06-26-2016, 06:38 PM
RE: Sherwood S-7900A - by Ed Locker - 06-27-2016, 08:35 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-27-2016, 03:27 PM
RE: Sherwood S-7900A - by Arran - 06-28-2016, 03:15 AM
RE: Sherwood S-7900A - by Ron Ramirez - 06-28-2016, 06:55 PM
RE: Sherwood S-7900A - by Arran - 06-29-2016, 03:15 AM
RE: Sherwood S-7900A - by Ron Ramirez - 12-22-2016, 09:58 PM
RE: Sherwood S-7900A - by morzh - 12-22-2016, 10:31 PM
RE: Sherwood S-7900A - by Ron Ramirez - 12-22-2016, 11:09 PM
RE: Sherwood S-7900A - by morzh - 12-22-2016, 11:15 PM
RE: Sherwood S-7900A - by Ron Ramirez - 12-23-2016, 08:38 AM
RE: Sherwood S-7900A - by morzh - 12-23-2016, 09:12 AM
RE: Sherwood S-7900A - by Ron Ramirez - 12-23-2016, 03:25 PM
RE: Sherwood S-7900A - by rocketeer - 12-23-2016, 07:55 PM
RE: Sherwood S-7900A - by KCMike - 12-23-2016, 08:48 PM
RE: Sherwood S-7900A - by Ron Ramirez - 05-22-2018, 09:18 PM
RE: Sherwood S-7900A - by morzh - 05-22-2018, 10:06 PM
RE: Sherwood S-7900A - by Ron Ramirez - 05-23-2018, 05:06 AM
RE: Sherwood S-7900A - by morzh - 05-23-2018, 06:39 AM
RE: Sherwood S-7900A - by Ron Ramirez - 05-23-2018, 08:08 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
