Model and date of Philco radio
Hi,
I'm new to Philco radios. I just purchased this one at an estate sale. It was working when I bought it, but after bringing it home, I have not plugged it in. I am not sure how to find the model number, so I would appreciate if anyone can recognize the model and year.
thanks,
earnestly
Model and date of Philco radio - by earnestly - 03-17-2017, 04:15 PM
RE: Model and date of Philco radio - by sam - 03-17-2017, 04:39 PM
RE: Model and date of Philco radio - by earnestly - 03-18-2017, 08:11 AM
RE: Model and date of Philco radio - by earnestly - 03-19-2017, 12:09 PM
RE: Model and date of Philco radio - by earnestly - 03-19-2017, 12:19 PM
RE: Model and date of Philco radio - by SteveG - 03-19-2017, 04:49 PM
RE: Model and date of Philco radio - by earnestly - 03-20-2017, 05:40 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 5307 online users. [Complete List]
» 2 Member(s) | 5305 Guest(s)
