Model and date of Philco radio
(03-19-2017, 06:22 PM)jerryhawthorne Wrote:  Is it just me or does that power transformer look huge?  Perhaps a 50 cycle radio?
Jerry
Not so much. It has the 10w class A output stage with requires a bit more current than the standard P/P 42 output stage.
Most if not all of the 25cy are out of Canada these have a metal tag riveted on the back apron.
Model and date of Philco radio - by earnestly - 03-17-2017, 04:15 PM
RE: Model and date of Philco radio - by sam - 03-17-2017, 04:39 PM
RE: Model and date of Philco radio - by earnestly - 03-18-2017, 08:11 AM
RE: Model and date of Philco radio - by earnestly - 03-19-2017, 12:09 PM
RE: Model and date of Philco radio - by earnestly - 03-19-2017, 12:19 PM
RE: Model and date of Philco radio - by SteveG - 03-19-2017, 04:49 PM
RE: Model and date of Philco radio - by Radioroslyn - 03-19-2017, 08:38 PM
RE: Model and date of Philco radio - by earnestly - 03-20-2017, 05:40 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
