Philco 3583 and 4264 restuffing need advice
I am looking to restuff these metal cans out of an Philco 70.
According to http://philcorepairbench.com/metalcap.htm
The 4264 is  0.25uf at 2000 V
The 3583 is 0.5 at 1200 V.
How are you getting 0.25uf at a working voltage of 2K in there ?
Looking at film cap sizes / working volts in series/parallel configs, I don't see how it is possible to fit these.
What am I missing ?  Is the "test voltage" not the working voltage we need to meet ?
Philco 3583 and 4264 restuffing need advice - by Ukhorse - 03-23-2017, 08:20 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 4844 online users. [Complete List]
» 2 Member(s) | 4842 Guest(s)
