Philco 81 Questions
#39
I have removed the ocillator coil. It looks to have an inner tube and winding on it. Do I have to remove it and how.
The secondary does show continuity. I took the old rotted windings off the primary. Going well.
Philco 81 Questions - by ohiobill - 02-26-2017, 04:56 PM
RE: Philco 81 Questions - by Ron Ramirez - 02-26-2017, 07:21 PM
RE: Philco 81 Questions - by klondike98 - 02-26-2017, 09:11 PM
RE: Philco 81 Questions - by ohiobill - 02-27-2017, 06:14 AM
RE: Philco 81 Questions - by Radioroslyn - 02-27-2017, 08:36 AM
RE: Philco 81 Questions - by ohiobill - 02-27-2017, 09:00 AM
RE: Philco 81 Questions - by KCMike - 02-27-2017, 09:48 AM
RE: Philco 81 Questions - by ohiobill - 02-27-2017, 10:52 AM
RE: Philco 81 Questions - by KCMike - 02-27-2017, 11:51 AM
RE: Philco 81 Questions - by morzh - 02-27-2017, 12:22 PM
RE: Philco 81 Questions - by Steve Davis - 02-27-2017, 01:06 PM
RE: Philco 81 Questions - by ohiobill - 02-27-2017, 01:49 PM
RE: Philco 81 Questions - by Radioroslyn - 02-27-2017, 02:04 PM
RE: Philco 81 Questions - by ohiobill - 02-27-2017, 07:14 PM
RE: Philco 81 Questions - by ohiobill - 02-28-2017, 01:00 PM
RE: Philco 81 Questions - by Mondial - 02-28-2017, 03:06 PM
RE: Philco 81 Questions - by Radioroslyn - 02-28-2017, 03:10 PM
RE: Philco 81 Questions - by ohiobill - 03-01-2017, 07:47 PM
RE: Philco 81 Questions - by klondike98 - 03-01-2017, 11:59 PM
RE: Philco 81 Questions - by ohiobill - 03-05-2017, 11:45 AM
RE: Philco 81 Questions - by Radioroslyn - 03-05-2017, 06:12 PM
RE: Philco 81 Questions - by ohiobill - 03-06-2017, 01:57 PM
RE: Philco 81 Questions - by klondike98 - 03-09-2017, 12:35 PM
RE: Philco 81 Questions - by Radioroslyn - 03-09-2017, 12:53 PM
RE: Philco 81 Questions - by ohiobill - 03-16-2017, 09:28 AM
RE: Philco 81 Questions - by Radioroslyn - 03-16-2017, 11:54 AM
RE: Philco 81 Questions - by ohiobill - 03-19-2017, 11:49 AM
RE: Philco 81 Questions - by Radioroslyn - 03-19-2017, 03:08 PM
RE: Philco 81 Questions - by ohiobill - 03-19-2017, 03:34 PM
RE: Philco 81 Questions - by ohiobill - 03-26-2017, 08:33 AM
RE: Philco 81 Questions - by Radioroslyn - 03-26-2017, 11:00 AM
RE: Philco 81 Questions - by ohiobill - 03-27-2017, 08:46 AM
RE: Philco 81 Questions - by ohiobill - 03-27-2017, 11:26 AM
RE: Philco 81 Questions - by morzh - 03-27-2017, 01:35 PM
RE: Philco 81 Questions - by ohiobill - 03-28-2017, 11:18 AM
RE: Fabric Covered Power Cord - by ohiobill - 02-26-2017, 05:00 PM
RE: Fabric Covered Power Cord - by Radioroslyn - 02-26-2017, 07:09 PM
model 81 capacitors - by ohiobill - 03-07-2017, 02:16 PM
RE: model 81 capacitors - by Radioroslyn - 03-07-2017, 02:31 PM
RE: model 81 capacitors - by morzh - 03-07-2017, 03:07 PM
RE: model 81 capacitors - by ohiobill - 03-07-2017, 06:11 PM
RE: model 81 capacitors - by Kenneth F. Besso Jr. - 03-07-2017, 07:13 PM
RE: model 81 capacitors - by Radioroslyn - 03-07-2017, 07:54 PM
RE: model 81 capacitors - by ohiobill - 03-07-2017, 07:55 PM
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3549 online users. [Complete List]
» 3 Member(s) | 3546 Guest(s)
