TrueTone Model D9?
What tubes are in it? You might compare these schematics against your chassis tube line up.
These are on Nostalgia air under western auto. D937 issue B --D938 issue A---940A & 940B
Not saying they are it, but I ran into a similar problem awhile back with a Western auto radio and found it under a different # than the one on my chassis.
TrueTone Model D9? - by WallaceRoger - 03-29-2017, 07:33 PM
RE: TrueTone Model D9? - by KCMike - 03-29-2017, 08:15 PM
RE: TrueTone Model D9? - by Arran - 03-29-2017, 09:50 PM
RE: TrueTone Model D9? - by WallaceRoger - 03-30-2017, 08:45 PM
RE: TrueTone Model D9? - by David - 03-31-2017, 06:57 PM
RE: TrueTone Model D9? - by Arran - 04-01-2017, 01:46 AM
RE: TrueTone Model D9? - by WallaceRoger - 04-03-2017, 03:20 PM
RE: TrueTone Model D9? - by Arran - 04-04-2017, 03:26 AM
RE: TrueTone Model D9? - by Radioroslyn - 04-03-2017, 09:56 PM
RE: TrueTone Model D9? - by Radioroslyn - 04-04-2017, 04:43 AM
RE: TrueTone Model D9? - by WallaceRoger - 04-04-2017, 02:07 PM
RE: TrueTone Model D9? - by WallaceRoger - 04-04-2017, 02:18 PM
RE: TrueTone Model D9? - by WallaceRoger - 04-30-2017, 11:26 AM
RE: TrueTone Model D9? - by WallaceRoger - 05-01-2017, 12:37 PM
RE: TrueTone Model D9? - by Eliot Ness - 05-01-2017, 01:03 PM
RE: TrueTone Model D9? - by WallaceRoger - 05-01-2017, 07:48 PM
RE: TrueTone Model D9? - by WallaceRoger - 07-24-2017, 08:36 PM
TrueTone Model D9 - by WallaceRoger - 08-08-2017, 09:44 PM
RE: TrueTone Model D9? - by Arran - 08-09-2017, 02:31 AM
RE: TrueTone Model D9? - by Paul Philco322 - 08-15-2017, 07:43 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
There are currently 5124 online users. [Complete List]
» 1 Member(s) | 5123 Guest(s)
