Philco Labels
Thanks very much Crist. Funny story - I started making labels *because* I ordered one from the same seller and was unhappy with the quality. Icon_rolleyes
Let me know if I can help. From the examples of that label I've seen online it's a bit of a tricky one to reproduce because it requires a gold background (which is normally OK - that just means printing on gold paper with a color laser printer) but also white lettering. Obviously most printers don't print white (or gold), which makes having both in the same label a bit of a problem. Probably the best you could do with a regular printer would be to print the golden-yellow rather than have it be metallic.
Philco Labels - by gregb - 12-23-2016, 06:15 PM
RE: Philco Labels - by OldRestorer - 12-23-2016, 06:52 PM
RE: Philco Labels - by Crist Rigotti - 12-25-2016, 07:25 AM
RE: Philco Labels - by joybird - 03-24-2017, 09:01 AM
RE: Philco Labels - by gregb - 12-23-2016, 07:26 PM
RE: Philco Labels - by Nathan Slingerland - 12-23-2016, 08:34 PM
RE: Philco Labels - by gregb - 12-23-2016, 08:44 PM
RE: Philco Labels - by Nathan Slingerland - 01-02-2017, 02:33 PM
RE: Philco Labels - by morzh - 03-24-2017, 09:06 AM
RE: Philco Labels - by sam - 03-24-2017, 07:42 PM
RE: Philco Labels - by Crist Rigotti - 04-01-2017, 03:38 PM
RE: Philco Labels - by Nathan Slingerland - 04-01-2017, 06:15 PM
RE: Philco Labels - by Crist Rigotti - 04-01-2017, 08:48 PM
RE: Philco Labels - by morzh - 04-01-2017, 06:32 PM
RE: Philco Labels - by Crist Rigotti - 04-01-2017, 08:46 PM
RE: Philco Labels - by morzh - 04-01-2017, 09:55 PM
RE: Philco Labels - by Crist Rigotti - 04-01-2017, 11:31 PM
RE: Philco Labels - by Greenhorn - 10-20-2017, 08:29 AM
Delco car radio Peko vibrator converstion issues
Rich, There is an Australian website (Cool386.com) that has much useful info regarding repair and restoration of vibr...Joe Rossi — 07:29 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3519 online users. [Complete List]
» 2 Member(s) | 3517 Guest(s)
