It is time: The Fisher TA-600
Threads: 24
City: Edmonton AB CA
Hi Ron:
In talking with a few different audio guys in the past they say best of the Russian output tubes are the ones in the link below. I have bought number of them from this fellow and have had good luck with him and the tubes are NOS and do sound really good to me and the prices are right as well. I have a few customers that ask for them specifically so others agree with them as well and they are a fraction of the price of RCA7189's.
http://www.ebay.com/itm/6P14P-EV-EL84-71...Sw241YdRbh
Gregb
RE: It is time: The Fisher TA-600 - by gregb - 04-04-2017, 07:34 PM
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
There are currently 5301 online users. [Complete List] » 1 Member(s) | 5300 Guest(s)
