It is time: The Fisher TA-600
Threads: 24
City: Edmonton AB CA
Sorry Ron, no its not plug and play, you have to buy an adaptor or rewire the socket. I went with adaptors as they are easy to use but I do try to stay with the original tube types when possible and use the adaptors when needed or for testing. The day may come when I have to rewire sockets as the 7199 tubes seem to be getting harder to buy for a reasonable price.
Gregb
(This post was last modified: 04-12-2017, 05:08 PM by gregb.)
RE: It is time: The Fisher TA-600 - by gregb - 04-12-2017, 05:07 PM
Jackson 715 not working
Now that you posted the schematic, I don't know why that Sprague electrolytic cap is across the meter, as it is not indi...MrFixr55 — 05:51 PM |
What may be lacking in the PP Tube amps may be the 2nd harmonics, which some, especially RCA back in the day called &quo...MrFixr55 — 05:32 PM |
Usually in an emission tester, the tube under test is measured as if it were a diode. So, some testers connect all the g...RodB — 04:17 PM |
Restoring Philco 37-604C
Yep. F5 is green, D5 is Red.
Red is Bad.
Green is Clean.morzh — 01:30 PM |
I did start to do that but I stalled out because I could not figure out how the grid and plate get voltage. In this diag...daveone23 — 11:52 AM |
(Insert Homer Simpson "DOPF" Here.)
When all fails, look at the can. Took the Ron Ramirez advice, red Caig D...MrFixr55 — 09:23 AM |
Philco 91 Speaker Replacement
From your text I am not sure if you intend to use the existing speaker with a resistor instead of the field coil.
It wo...morzh — 08:44 AM |
My field coil is bad. I am still hoping to find an original, but if I can't I will go with a fitting Philco speaker, 125...dconant — 08:34 AM |
As Rod said, it is OK to use a fitting speaker, and then look for an original one.
If you buy a Hammond 125 output tr...morzh — 08:15 AM |
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM |
There are currently 5361 online users. [Complete List] » 1 Member(s) | 5360 Guest(s)
