It is time: The Fisher TA-600
#76
Mondial
http://www.audiokarma.org/forums/index.p...on.676168/
They begin discussing the IBAM mod on page 3, and then you can see the schematic on page 4, post #66.
I haven't built mine yet. I spent last night studying the AudioKarma thread linked just above, looking at the PC board I have and the trimpots I bought, and starting to figure out just how to go about building it. I hope to start working on it tonight or tomorrow.
It is time: The Fisher TA-600 - by Ron Ramirez - 04-02-2017, 04:02 PM
RE: It is time: The Fisher TA-600 - by KCMike - 04-02-2017, 04:37 PM
RE: It is time: The Fisher TA-600 - by Mondial - 04-02-2017, 05:44 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-02-2017, 07:03 PM
RE: It is time: The Fisher TA-600 - by Arran - 04-05-2017, 01:52 AM
RE: It is time: The Fisher TA-600 - by rocketeer - 04-04-2017, 10:12 AM
RE: It is time: The Fisher TA-600 - by gregb - 04-04-2017, 07:34 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-04-2017, 07:39 PM
RE: It is time: The Fisher TA-600 - by Arran - 04-05-2017, 01:12 AM
RE: It is time: The Fisher TA-600 - by morzh - 04-05-2017, 07:50 AM
RE: It is time: The Fisher TA-600 - by Arran - 04-06-2017, 08:58 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-04-2017, 08:53 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-04-2017, 10:09 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-06-2017, 06:42 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-06-2017, 09:31 PM
RE: It is time: The Fisher TA-600 - by Arran - 04-10-2017, 04:03 AM
RE: It is time: The Fisher TA-600 - by TV MAN - 04-11-2017, 09:06 PM
RE: It is time: The Fisher TA-600 - by Arran - 04-11-2017, 10:15 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-12-2017, 10:00 AM
RE: It is time: The Fisher TA-600 - by gregb - 04-12-2017, 05:07 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-12-2017, 06:53 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-16-2017, 08:01 PM
RE: It is time: The Fisher TA-600 - by Ed Locker - 04-17-2017, 08:40 AM
RE: It is time: The Fisher TA-600 - by morzh - 04-17-2017, 09:43 AM
RE: It is time: The Fisher TA-600 - by gregb - 04-17-2017, 06:47 PM
RE: It is time: The Fisher TA-600 - by rocketeer - 04-17-2017, 07:53 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-17-2017, 08:02 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-17-2017, 09:47 PM
RE: It is time: The Fisher TA-600 - by Mondial - 04-17-2017, 11:12 PM
RE: It is time: The Fisher TA-600 - by Arran - 04-20-2017, 10:24 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-19-2017, 08:52 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-20-2017, 08:56 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-20-2017, 09:01 PM
RE: It is time: The Fisher TA-600 - by Arran - 04-20-2017, 10:31 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-21-2017, 07:22 AM
RE: It is time: The Fisher TA-600 - by Mondial - 04-21-2017, 07:28 AM
RE: It is time: The Fisher TA-600 - by Ron Ramirez - 04-21-2017, 08:31 AM
RE: It is time: The Fisher TA-600 - by morzh - 04-21-2017, 11:57 AM
RE: It is time: The Fisher TA-600 - by gregb - 04-21-2017, 08:04 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-21-2017, 08:41 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-21-2017, 08:52 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-22-2017, 12:31 PM
RE: It is time: The Fisher TA-600 - by Mondial - 04-22-2017, 02:05 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-22-2017, 06:42 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-22-2017, 07:06 PM
RE: It is time: The Fisher TA-600 - by Mondial - 04-26-2017, 09:50 PM
RE: It is time: The Fisher TA-600 - by TV MAN - 04-27-2017, 06:57 AM
RE: It is time: The Fisher TA-600 - by Mondial - 04-27-2017, 01:46 PM
RE: It is time: The Fisher TA-600 - by Mondial - 04-27-2017, 02:12 PM
RE: It is time: The Fisher TA-600 - by TV MAN - 04-27-2017, 06:55 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-27-2017, 09:22 PM
RE: It is time: The Fisher TA-600 - by morzh - 04-28-2017, 06:52 AM
RE: It is time: The Fisher TA-600 - by TV MAN - 04-28-2017, 04:40 PM
RE: It is time: The Fisher TA-600 - by rocketeer - 04-28-2017, 08:19 PM
RE: It is time: The Fisher TA-600 - by gregb - 04-28-2017, 08:32 PM
RE: It is time: The Fisher TA-600 - by rocketeer - 04-29-2017, 07:56 AM
RE: It is time: The Fisher TA-600 - by Arran - 04-30-2017, 05:38 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3905 online users. [Complete List]
» 1 Member(s) | 3904 Guest(s)
