Philco 37-630, Low volume, 1st IF problems??
Hi Bob,
Yes, the red terminal is where you should connect the antenna.  If you attach a 5-10 foot wire, that should be sufficient to receive a strong local station.
Another thing to check would be the AVC resistor (R44).  This should be a 1meg resistor.  Did you replace this resistor?  If it was open or if it's value is significantly higher, then the gain in the first stages will be reduced.
Jon
RE: Philco 37-630, Low volume, 1st IF problems?? - by PAradiogeek - 04-23-2017, 07:11 PM
