46-1226 code 125 restoratioin *DONE
Threads: 42
City: Gap Mills Wv 24941
now you can see i went from what would be considred a good original replacement choice by the "numbers" but in practice it failed.
my blue 300 ohm was porcelain design.
my green 500 ohm is porcelain and hollow in design with my fabricated heat sync & inserted copper tubuing in the center.
I believe my 500ohm solution is probably 5 times larger in size and should suit the application but it does not.
I suspect that :
A- i still have a problem somewhere like someone said earlier or.....
B- the circuit is talking to me, telling me i need to actually be somwhere in the 120w range.
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:12 AM
Philco 39-116 radio and remote
Hi Brad,
Thanks so much for the info! Do you happen to have the specs for the PT-86 transformer? I did not find a lis...RichG — 04:32 PM |
Philco 269 - 444 FIVE VALVE VERSION?
Thanks Arran;
If your set has five tubes/valves then it could be an A537, V537, or a U527, then again it looks like s...ChasL0001 — 11:07 AM |
Philco 29 or 45
29 chassis has a shadow meter while 45 chassis does not. Shadow meter is part no. 27 in the 29 schematic. compare it t...klondike98 — 10:32 AM |
Sorry, Chas.
Re the burns, I broke my first TV at the age of 3. Between my electrical experiments :yikes: (My mom wa...MrFixr55 — 09:07 AM |
Philco 41-221 Restored
Thanks for the compliment Richard. The tenite grille is original. A few of the horizontal slats were slightly warped so ...RodB — 08:44 AM |
Philco 29 or 45
Hello, I have just received a Philco lowboy where the tube layout label in the cabinet says 29 or 45. There is no label ...dconant — 08:29 AM |
Mr fixr,
That is great news I would love to see repo grille !!
I too have a very similar Philco but my cabinet has fab...radiorich — 08:22 AM |
Hi Rod,
I always tell people that my scars give me character. :wink: Great job on the radio. Is the grille origi...MrFixr55 — 08:00 AM |
It looks like the PENDD61 valve/tube must have failed, so someone replaced it with the EBC33, which is a double diode-tr...Arran — 04:29 AM |
Hello Chas. Radiomuseum has information on both sets.
Thanks Gary, lots of good info there.
Perhaps we'll ha...ChasL0001 — 02:23 AM |
There are currently 1982 online users. [Complete List] » 1 Member(s) | 1981 Guest(s)
