TrueTone Model D9?
(05-01-2017, 12:37 PM)WallaceRoger Wrote:  Does anyone know what this mystery (to me) part is?
Can you see where at least one end of it connects to?  See if its location corresponds with R11 (or maybe R12 or 13).
From what I can make out it almost looks homemade.  Is it a piece that broke off from the part under the tape with the #4 on it ?
TrueTone Model D9? - by WallaceRoger - 03-29-2017, 07:33 PM
RE: TrueTone Model D9? - by KCMike - 03-29-2017, 08:15 PM
RE: TrueTone Model D9? - by Arran - 03-29-2017, 09:50 PM
RE: TrueTone Model D9? - by WallaceRoger - 03-30-2017, 08:45 PM
RE: TrueTone Model D9? - by David - 03-31-2017, 06:57 PM
RE: TrueTone Model D9? - by Arran - 04-01-2017, 01:46 AM
RE: TrueTone Model D9? - by WallaceRoger - 04-03-2017, 03:20 PM
RE: TrueTone Model D9? - by Arran - 04-04-2017, 03:26 AM
RE: TrueTone Model D9? - by Radioroslyn - 04-03-2017, 09:56 PM
RE: TrueTone Model D9? - by Radioroslyn - 04-04-2017, 04:43 AM
RE: TrueTone Model D9? - by WallaceRoger - 04-04-2017, 02:07 PM
RE: TrueTone Model D9? - by WallaceRoger - 04-04-2017, 02:18 PM
RE: TrueTone Model D9? - by WallaceRoger - 04-30-2017, 11:26 AM
RE: TrueTone Model D9? - by WallaceRoger - 05-01-2017, 12:37 PM
RE: TrueTone Model D9? - by Eliot Ness - 05-01-2017, 01:03 PM
RE: TrueTone Model D9? - by WallaceRoger - 05-01-2017, 07:48 PM
RE: TrueTone Model D9? - by WallaceRoger - 07-24-2017, 08:36 PM
TrueTone Model D9 - by WallaceRoger - 08-08-2017, 09:44 PM
RE: TrueTone Model D9? - by Arran - 08-09-2017, 02:31 AM
RE: TrueTone Model D9? - by Paul Philco322 - 08-15-2017, 07:43 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
