  • 1 Vote(s) - 4 Average
46-1226 code 125 restoratioin *DONE
updated voltage results above....
on the candohm R100, i was also at least expecting something like -15v per the diagram-  46-1226 code 125 power supply update to the far right.
T100 center tap of the hv secondary (green) to>
terminal strip to>
white wire to>
C101 filter cap group (parallel caps with negatives tied to>
one side of R100 candohm to>
chassis.
if you look at the prints... Filter cap C102 negative can bond to chassis direclty.
Filter cap C101 can not be bonded directly to chassis, it must go through R100 before getting to chassis.
46-1226 code 125 restoratioin *DONE - by jcassity - 03-19-2017, 10:03 AM
RE: 46-1226 code 125 restoratioin - by klondike98 - 03-19-2017, 12:57 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-19-2017, 05:31 PM
RE: 46-1226 code 125 restoratioin - by David - 03-20-2017, 06:52 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 03-20-2017, 09:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 10:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 10:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 10:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-23-2017, 08:18 PM
RE: 46-1226 code 125 restoratioin - by Arran - 03-23-2017, 11:24 PM
RE: 46-1226 code 125 restoratioin - by morzh - 03-24-2017, 09:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-24-2017, 09:45 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-28-2017, 11:47 AM
RE: 46-1226 code 125 restoratioin - by sam - 03-28-2017, 12:44 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-30-2017, 07:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 12:20 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 12:32 PM
RE: 46-1226 code 125 restoratioin - by David - 03-31-2017, 06:46 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 08:39 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 02:12 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 11:03 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 08:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-04-2017, 09:24 PM
RE: 46-1226 code 125 restoratioin - by Arran - 04-04-2017, 10:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-05-2017, 01:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 09:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 03:33 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-07-2017, 09:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-08-2017, 12:49 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-13-2017, 08:30 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-14-2017, 06:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 09:32 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 09:42 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-15-2017, 11:13 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 08:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 09:00 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-16-2017, 09:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 09:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-17-2017, 05:36 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-17-2017, 07:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-19-2017, 07:19 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 07:54 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 03:49 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 09:06 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 08:24 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 08:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 08:56 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 09:04 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 09:08 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 09:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 09:49 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 10:31 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 11:40 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 11:55 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 11:59 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 08:35 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 07:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 08:00 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 08:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 05:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 05:32 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-22-2017, 06:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:15 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-22-2017, 09:22 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-22-2017, 10:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 08:38 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-23-2017, 09:34 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 09:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-24-2017, 07:34 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 02:44 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-25-2017, 05:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 05:12 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-26-2017, 10:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-27-2017, 05:52 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 09:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 05:41 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-28-2017, 08:44 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-28-2017, 09:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 09:49 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 10:17 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 01:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 02:17 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 02:18 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 02:40 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 03:41 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 03:43 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 05:10 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 07:11 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 07:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 07:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 08:42 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 08:52 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 08:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 11:19 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 06:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:12 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:18 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:27 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-30-2017, 09:20 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-30-2017, 10:56 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 09:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 10:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 10:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 09:27 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 07:31 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:05 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 08:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:18 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 08:27 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:53 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 12:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 01:40 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 01:50 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 02:13 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 02:16 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 03:10 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 03:19 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 04:31 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 04:31 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 06:23 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 06:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-03-2017, 07:58 AM
RE: 46-1226 code 125 restoratioin - by criageek - 05-03-2017, 11:23 AM
RE: 46-1226 code 125 restoratioin - by criageek - 05-04-2017, 09:02 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-04-2017, 09:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 09:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 06:45 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 08:48 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 09:50 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 09:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-06-2017, 09:51 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-06-2017, 01:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:26 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:37 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 08:47 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-07-2017, 10:00 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 05:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 05:49 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 09:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 09:19 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-10-2017, 10:54 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 11:32 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 09:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 09:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 09:28 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-13-2017, 03:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-15-2017, 07:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 09:50 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 09:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 09:58 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 05:15 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 01:09 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 05:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 06:38 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 07:18 AM
RE: 46-1226 code 125 restoratioin *DONE - by sam - 05-22-2017, 09:45 PM
Antenna options - by jcassity - 05-19-2017, 06:04 AM
