  • 1 Vote(s) - 4 Average
46-1226 code 125 restoratioin *DONE
i posted it a few posts  back ,, not sure if it was improper to do so since i had to get it from the philco workbench.
you can not use this diagram as a stand alone for any 46-1226 code 125 because there are a lot of big and small changes,, which i posted in other posts... i bundled all the changes into one picture so you see the progression from code 121, code 122 and code 125.
here it is
like pin 7 is supposed to be the shown value but i have 13.5v
Pin 6 is i think ridiing close to 300v..
some voltage readings are very dead on.
what i am going to do later tonight after i finish tilling the garden is start poking around at the internal antenna thing, my L400 to see if i can gently wiggle test to get shortwave to come in.
I had what i felt was an issue soldering a wire to L403,, its like the metal tang moved!  this little bugger is right on the band selector switch so i need to ohm check it as well.
46-1226 code 125 restoratioin *DONE - by jcassity - 03-19-2017, 10:03 AM
RE: 46-1226 code 125 restoratioin - by klondike98 - 03-19-2017, 12:57 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-19-2017, 05:31 PM
RE: 46-1226 code 125 restoratioin - by David - 03-20-2017, 06:52 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 03-20-2017, 09:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 10:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 10:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-21-2017, 10:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-23-2017, 08:18 PM
RE: 46-1226 code 125 restoratioin - by Arran - 03-23-2017, 11:24 PM
RE: 46-1226 code 125 restoratioin - by morzh - 03-24-2017, 09:11 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-24-2017, 09:45 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-28-2017, 11:47 AM
RE: 46-1226 code 125 restoratioin - by sam - 03-28-2017, 12:44 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-30-2017, 07:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 12:20 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 03-31-2017, 12:32 PM
RE: 46-1226 code 125 restoratioin - by David - 03-31-2017, 06:46 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 08:39 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 02:12 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-04-2017, 11:03 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-03-2017, 08:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-04-2017, 09:24 PM
RE: 46-1226 code 125 restoratioin - by Arran - 04-04-2017, 10:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-05-2017, 01:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 09:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-06-2017, 03:33 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-07-2017, 09:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-08-2017, 12:49 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-13-2017, 08:30 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-14-2017, 06:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 09:32 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-15-2017, 09:42 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-15-2017, 11:13 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 08:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 09:00 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-16-2017, 09:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-16-2017, 09:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-17-2017, 05:36 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-17-2017, 07:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-19-2017, 07:19 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 07:54 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 03:49 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-19-2017, 09:06 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 08:24 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-20-2017, 08:30 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 08:56 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 09:04 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 09:08 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 09:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-21-2017, 09:49 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 10:31 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 11:40 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 11:55 AM
RE: 46-1226 code 125 restoratioin - by criageek - 04-21-2017, 11:59 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-21-2017, 08:35 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 07:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 08:00 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 08:05 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 05:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 05:32 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-22-2017, 06:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:13 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-22-2017, 09:15 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-22-2017, 09:22 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-22-2017, 10:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 08:38 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-23-2017, 09:34 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-23-2017, 09:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-24-2017, 07:34 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 02:44 PM
RE: 46-1226 code 125 restoratioin - by criageek - 04-25-2017, 05:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-25-2017, 05:12 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-26-2017, 10:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-27-2017, 05:52 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 09:06 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 05:41 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-28-2017, 08:44 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-28-2017, 09:08 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-28-2017, 09:49 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 10:17 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 01:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 02:17 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 02:18 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 02:40 PM
RE: 46-1226 code 125 restoratioin - by gregb - 04-29-2017, 03:41 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 03:43 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 05:10 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 07:11 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 07:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 07:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 08:42 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-29-2017, 08:52 PM
RE: 46-1226 code 125 restoratioin - by morzh - 04-29-2017, 08:53 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-29-2017, 11:19 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 06:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:12 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:18 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 07:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 08:27 AM
RE: 46-1226 code 125 restoratioin - by morzh - 04-30-2017, 09:20 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 04-30-2017, 10:56 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 04-30-2017, 09:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 10:36 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 10:53 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-01-2017, 09:27 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 07:31 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:05 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 08:07 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:18 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 08:27 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 08:53 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 12:54 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 01:40 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 01:50 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 02:13 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 02:16 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 03:10 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 03:19 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-02-2017, 04:31 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-02-2017, 04:31 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 06:23 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-02-2017, 06:36 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-03-2017, 07:58 AM
RE: 46-1226 code 125 restoratioin - by criageek - 05-03-2017, 11:23 AM
RE: 46-1226 code 125 restoratioin - by criageek - 05-04-2017, 09:02 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-04-2017, 09:16 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 09:02 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 06:45 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 08:48 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-05-2017, 09:50 PM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-05-2017, 09:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-06-2017, 09:51 AM
RE: 46-1226 code 125 restoratioin - by Mondial - 05-06-2017, 01:25 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:21 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:26 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:33 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 10:37 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-07-2017, 08:47 PM
RE: 46-1226 code 125 restoratioin - by criageek - 05-07-2017, 10:00 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 05:47 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 05:49 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-08-2017, 09:30 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 09:19 AM
RE: 46-1226 code 125 restoratioin - by morzh - 05-10-2017, 10:54 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-10-2017, 11:32 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 09:07 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 09:15 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-11-2017, 09:28 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-13-2017, 03:56 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-15-2017, 07:09 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 09:50 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 09:55 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-18-2017, 09:58 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 05:15 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-19-2017, 01:09 PM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 05:58 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 06:38 AM
RE: 46-1226 code 125 restoratioin - by jcassity - 05-21-2017, 07:18 AM
RE: 46-1226 code 125 restoratioin *DONE - by sam - 05-22-2017, 09:45 PM
Antenna options - by jcassity - 05-19-2017, 06:04 AM
