Philco 96 help please
Thanks for your reply and links to the schematics! This will be very helpful. I'm a newbie at this and trying to do all the research I can before I dig in so I'm really happy I found this forum
I'm not sure if this is the same 96 you are asking about...my wife found it on Facebook and I picked it up from the seller this past week.  Links to pics below if you want to see it....seems to be in mint condition  Icon_biggrin  Hope the links work
http://imgur.com/4tCQ13c
http://imgur.com/omLAQT4
Philco 96 help please - by KYNole - 05-27-2017, 05:13 PM
RE: Philco 96 help please - by Ron Ramirez - 05-27-2017, 06:06 PM
RE: Philco 96 help please - by klondike98 - 05-27-2017, 07:18 PM
RE: Philco 96 help please - by KYNole - 05-27-2017, 07:27 PM
RE: Philco 96 help please - by KYNole - 05-27-2017, 07:32 PM
RE: Philco 96 help please - by klondike98 - 05-27-2017, 07:51 PM
RE: Philco 96 help please - by Ron Ramirez - 05-27-2017, 07:55 PM
RE: Philco 96 help please - by KYNole - 05-27-2017, 08:12 PM
RE: Philco 96 help please - by morzh - 05-27-2017, 08:23 PM
RE: Philco 96 help please - by GarySP - 05-27-2017, 08:29 PM
RE: Philco 96 help please - by morzh - 05-27-2017, 08:47 PM
RE: Philco 96 help please - by KYNole - 05-27-2017, 09:15 PM
RE: Philco 96 help please - by Radioroslyn - 05-27-2017, 09:17 PM
RE: Philco 96 help please - by KYNole - 05-27-2017, 09:42 PM
RE: Philco 96 help please - by Radioroslyn - 05-27-2017, 10:07 PM
RE: Philco 96 help please - by Radioroslyn - 05-27-2017, 10:37 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3917 online users. [Complete List]
» 1 Member(s) | 3916 Guest(s)
