Cleaning Loctal Corrosion
I doubt it is steel. Could be brass, plated with tin or something.
Cleaning Loctal Corrosion - by Nick3092 - 06-21-2017, 05:04 PM
RE: Cleaning Loctal Corrosion - by Jim Koehler - 06-21-2017, 05:35 PM
RE: Cleaning Loctal Corrosion - by jcassity - 06-21-2017, 08:57 PM
RE: Cleaning Loctal Corrosion - by WallaceRoger - 06-22-2017, 03:25 PM
RE: Cleaning Loctal Corrosion - by morzh - 06-22-2017, 03:29 PM
RE: Cleaning Loctal Corrosion - by Arran - 06-25-2017, 03:20 PM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
There are currently 3889 online users. [Complete List]
» 1 Member(s) | 3888 Guest(s)
