Philco model 048 set tester
found that the500ohm wirewound potentiometer is bad. Not sure if its termed a wirewound but beleive so.You can plainley see inside the pot andwatch the arm rotatearound the wire. What should I use to replace this pot? I can,t seem to locate this pot on the schematic.It is the attenuation control. Are there still some of theses style of pots around? Thanks
Philco model 048 set tester - by Blaine - 01-31-2010, 02:48 PM
Re: Philco model 048 set tester - by codefox1 - 01-31-2010, 03:43 PM
Re: Philco model 048 set tester - by Blaine - 01-31-2010, 07:28 PM
Re: Philco model 048 set tester - by Blaine - 02-06-2010, 07:22 AM
Re: Philco model 048 set tester - by 7estatdef - 02-06-2010, 09:22 AM
Re: Philco model 048 set tester - by codefox1 - 02-06-2010, 01:25 PM
