02-07-2010, 03:01 PM
I'm the other member. As Ron said I did check the plate voltage on the detector and found 230v. Latter I was just sitting around and perusing the model 70 info. It sez plate voltage 105v. So I thought I'd give it another check. This time I used my old faithful Triplet 630 ( just a vom 20K per volt). Nice old Bakelite job that will measure up to 6KV handy for working on old 7" electrostatic deflection TV sets. Any away I digress. It sez 215vdc. I'm pretty sure that I did go through the resistors and check them when I serviced it. Something else to have a look at. Set play fine as a matter of fact it's on now playing Tales of the Texas Rangers. I'm using an old signal generator as a low power AM station.
