Philco 38-4 wire identification??
You can safely power it up if you remove the 5Y4 tube. This prevents any hv dc being applied throughout the set. At this point you can measure the hv ac at pin 3 to pin 5 of the 5Y4 without the tube plugged in. Should see about 600vac between these pins. Your set uses octal tubes (see socket in middle of pictorial). All of the pictured are bottom views (from the underside of the chassis) not the top.
Check ur PM box.
[Image: http://electriciantraining.tpub.com/1417...8_24_2.jpg]
Philco 38-4 wire identification?? - by CodyTerry - 10-15-2017, 08:13 PM
RE: Philco 38-4 wire identification?? - by Radioroslyn - 10-16-2017, 07:33 PM
