Wood Type Question
On he stripe inlays, my guess will be ebony. The panels were walnut veneered with some more decorative combinations, such as V-matching the grain. The sides of the cabinets were a "whitewood", such as poplar, gum, or basswood. In general, the panels will stain well, if you are doing a complete refinish. I have a 620, where the walnut stained to a kind of dishwater drab grayish....yech. After a sealer coat, I used a coat or two of tinted lacquer, and got some color into it, and it looks fine now.
The sides, especially the shouldered tombstones are shot with a sealer clear coat, then lay on successive tinted lacquer coats as necessary to get the color, then finish with a clear coat or two.
Wood Type Question - by Derek D - 01-24-2006, 12:31 PM
wood types - by Doug Houston - 01-24-2006, 06:47 PM
[No subject] - by Derek D - 02-06-2006, 10:24 AM
Jackson 715 not working
Restoring Philco 37-604C
Philco 91 Speaker Replacement
Yes, I often have to substitute, then keep an eye out for an original. In the meantime, the radio is working and being e...RodB — 08:02 AM
