41-608 code 122
you can always use a cap that is rated at a higher voltage and conveniently they sell film caps rated at 600 or 630v for all the caps that are less than 1uF.
I buy them at Just Radios but there are other places as folks have said. Just Radios has some nice tutorial info as well, for example: http://www.justradios.com/captips.html
and the info on safety caps: http://www.justradios.com/safetytips.html
The two 0.01uF caps labelled as #81 on the Riders schematic should each be a Y2 safety capacitor.
The 8-12-16 uF electrolytics (cap #21) will likely have to be purchased as 3 separate electrolytics and then wired in or it may be possible to stuff them into the existing can after it has been gutted. (I've not worked on a 41-608 so I'm not sure how big that can is). I also don't know the voltage rating for these so you either need to get that info off the existing cap or perhaps someone else here can offer a voltage rating suggestion.
I don't know about the 100uF cap either, I don't see it on the schematic.(if you are looking at cap#58...that is a 100uuF or 100 pF cap...and probably does not need replacing)
41-608 code 122 - by PhilcoDom - 10-19-2017, 12:03 PM
RE: 41-608 code 122 - by klondike98 - 10-29-2017, 08:03 AM
RE: 41-608 code 122 - by OldRestorer - 10-29-2017, 09:25 AM
RE: 41-608 code 122 - by Radioroslyn - 10-29-2017, 12:50 PM
RE: 41-608 code 122 - by PhilcoDom - 11-05-2017, 02:27 PM
RE: 41-608 code 122 - by sam - 11-05-2017, 05:11 PM
RE: 41-608 code 122 - by klondike98 - 11-05-2017, 08:53 PM
RE: 41-608 code 122 - by PhilcoDom - 12-29-2017, 05:55 PM
RE: 41-608 code 122 - by morzh - 12-29-2017, 06:58 PM
RE: 41-608 code 122 - by morzh - 12-29-2017, 07:41 PM
RE: 41-608 code 122 - by PhilcoDom - 12-30-2017, 08:22 PM
RE: 41-608 code 122 - by morzh - 12-30-2017, 08:23 PM
RE: 41-608 code 122 - by PhilcoDom - 12-30-2017, 08:38 PM
RE: 41-608 code 122 - by sam - 12-31-2017, 05:44 PM
RE: 41-608 code 122 - by sleuth255 - 04-14-2018, 08:39 AM
RE: Philco 41-608 - by Radioroslyn - 10-19-2017, 02:46 PM
RE: Philco 41-608 - by klondike98 - 10-19-2017, 02:55 PM
RE: Philco 41-608 - by PhilcoDom - 10-20-2017, 10:11 AM
RE: Philco 41-608 - by PhilcoDom - 10-28-2017, 07:00 PM
RE: Philco 41-608 - by Radioroslyn - 10-28-2017, 07:52 PM
RE: Philco 41-608 - by morzh - 10-28-2017, 08:31 PM
RE: Philco 41-608 - by PhilcoDom - 10-28-2017, 08:40 PM
